Another wood ID
dickm
25 Oct 2004
North of Aberdeen
Cutting up wood for the stove this afternoon and came across an interesting one. The whole piece was only about 30" long, 6 or 7" diameter. Bark looked like yew at first glance, so was thinking it might be interesting for turning, so went at it with chainsaw. Which was not happy; thought it must have done a banana cut and was binding, but the cut was fine. The cut surface obviously wasn't yew, as it was a uniform creamy white. Decided to try and split it to see what the lengthwise figure might be. OK, my axe had been doing a lot of splitting this winter, so isn't the sharpest, but it just bounced off the end grain. Cut the log in half on the bandsaw and planed up the surface to get a bit more information, as in the pics below. So what do folk reckon it might be? Two other clues; it's slightly denser than water so just sinks. The other (non) clue is that it came from the University Botanic Garden, so could be ANYTHING, UK or exotic.
    124.6 KB
    124 KB
    119.9 KB
The second and third pictures look like Sycamore to me. I don't think it's Hawthorn as that changes colour to orange as it oxidises when first in contact with air.............dom
Pretty sure it's not hawthorn, for the reasons above and it doesn't look to me like hawthorn bark. Sycamore, or at least something in the Acer family, does sound plausible and it's almost the right bark, but I've never encountered sycamore that hard, or that dense.
Will have to try serious use of Hoadley!
If it is holly, and you want to make something out of it you should research into drying it .
I think there is a lengthy discussion on this forum .
Basically if not done correctly, it will take on a not so nice,green tinge and not be as white as it should be.
Love this forum :D
Pretty sure that's not holly (bark is too dark and rough), hawthorn (wood it too pale) or sycamore (wrong bark again) .
Not much help as I haven't the foggiest at what it is.
Cinimod":3binxdfv said:
Just a thought, why don't you contact the Botanic gardens that it came from?............Dom
Yes, will be doing that - I need another load of wood to keep us warm for the remainder of the winter.
And, in passing, I've still got a lot of laburnum that came from the same source if anyone want some!
I'd go post on ArbTalk, a bunch of v. knowledgeable folk over there. Many will not read your post and ask for pictures of the leaves etc, but expect someone will give you an answer.
F.
