Lord Nibbo
Edited 23rd February......
Now all the pics have been added to this thread you can view the pics as a slide show and full screen size by clicking HERE
Sorry yes it's another Tool Cabinet, I'll say sorry now if you get bored easily. :wink:
Well you've seen the SketchUp design and there was a few changes, mainly to the overall size or I should say height. The first SketchUp was 48" tall this was reduced to 42" after realizing it would hit the rails of my garage doors when opened
I also reduced the number of drawers along the bottom from three layers to two.
Here's a reminder pic of the design.
I then thought I would need about two sheets of Maple veneered mdf to make it but I was way out.
The last time I used any quantity of sheet plywood I used to use optimic to do a cutlist but I lost the programme when I replaced my computer a year or so back, anyway I downloaded a 30 day trial of Smart2D Cutlistlist, I found it quite easy to use but after listing in all the pieces I needed I found out that I was limited to 30 parts per project
and even worse than that I found out I couldn't print out the cut list plans
So not to be out done I painstakingly copied each page and drew a rough plan using photoshop, here is one of the plans I drew.
So I needed four sheet or to be exact three and a quarter sheets, not the two I imagined I would need
I have a local stockist of sheet material "William Edens" for four sheets of 1/2" maple veneered mdf they quoted something close to £240 inc vat, I phoned around and found "Brittons" in Saltash could supply the same for £160
Up until now I thought William Edens were pretty good but now I know different.
Here's what you might call an artist impression of what the finished cabinet should look like.
I collected the panels this morning, I'll make a start on it in the morning and post later with how it's going.
