Hi
I have got a Wivamac lathe that has not had much use but has been standing around unused for several years. I have used it quite a bit recently as I have been getting back into turning and it is causing me some concern. The issues are as follows:-
1. When spindle turning last night I made a partial cut with a parting tool but when I later cut down to the end of the cut I found that the original cut did not co-incide with the later one. In other words when I made the later cut, finishing with a scraper, I found that the parting tool cut was removed on part of the cylinder but not all of it. One cut seemed to be on a different radius to the other. I hope that that makes sense!!!
2. When using either a spindle gouge or a bowl gouge there is an unpleasant squealing noise when rubbing the bevel.
3. The motor seemed to get excessively hot after running for about an hour or so but it sounded OK.
4. When running the lathe at high speed (3000 rpm) there was a very noticeable vibration even though the wood had been cut to an even cylinder.
Does this sound like knackered bearings? My Wivamac handbook does give instructions for changing the bearings. Any suggestions would be very welcome. Thanks.
