Paul.J
Hi Bill.
You have gotta make a decision if you think the wood has gone too far or not,if it has then its not worth bothering with Bill.
I roughed my two pieces down to what i thought was decent wood,inside and out leaving a good 25mm wall thickness even though it was still punky in parts i was managing to get a decent finish from the tool which was sharpened again once i started getting into the finishing cuts.
Use the bowl gouge in a shear scraping position on the outer with as light a cut as you can get.
If you are getting a smooth-ish finish from the tool carry on all over then apply the sanding sealer so it soaks through to the inside or if there are bad patches add some thin CA glue.
Leave to dry till hard then sharpen the gouge again and shear scrape again.If you feel the wood is giving you a good finish carry on and possibly add a second coat of SS and work down to your required finish.
If neccessary use a rough abrasive such as 60 grit.As the wood is soft it soon cuts through then work through the other grades.
As i said above i took the top 2" off the second bowl as i just knew the spalting had gone too far so didn't even try to save it.
Once the wood starts spalting the process just carriies on and it doesn't take it long to go too far.So if you are spalting wood you must keep a close eye on it to get any use out of it.
