Barry Burgess
You can use spiral tube(metal) from CCL or you can use waste pipe but it is not standard diameter for most of the blastgates etc. Waste pipe is 110mm or 160mm where as the standard is 100mm or 150mm.martlewis":wzbwe72g said:Where does everyone buy their ducting and what do you use? Have seen aluminium spiral ducting but I was also thinking pvc? Any suggestions?
I used waste pipe and modified the diameter at the blasgates like this
Barry
![PipeWork8.jpg](https://proxy.imagearchive.com/958/958b15de055d28e8f41078ed81d80e82.jpg)
