I designed and made this just in time for Christmas for SWMBO. It's made from a batch of rustic grade English Oak i aquired about 7 years ago.
I machined all the Oak and glued up 2 book matched pieces for the bottom. Whilst drying i made templates for all the shaped pieces from mdf and then cut out the 8 pieces for the cabinet and draw box. Quickly dovetailed together-
I rebated the back of the cabinet to take a 6mm MDF board and attached the draw box to the cabinet with screws. Screwed from inside the box.
A final sand and 3 coats of danish oil-
Prior to oiling the draw components where fitted to the draw box, and dovetailed and assembled-
The draw front was cut from a thicker section and shaped to match the bottom shelf. A small carved pull made from Laburnum was made and fitted, with a small mortice and tenon, i also carved a slight 'dish' above and below it-
The Mdf back was given 3 coats of blackboard paint, and screwed into the rebate. The draw front was oiled and fitted to the draw.
Finished and hung on the kitchen wall-
Thanks for looking!
Thanks for looking!
