Tris
What am I doing here?
When you want power!
Been researching this some more, and beginning to think my beast may actually have a Bosch unit, as there seem to be trigger modules on the market for the Bosch which look pretty much identical to mine. Unfortunately, the thread on the Arborist site doesn't have a picture of the one he repairs, which is a bit of a pain. All this leaves me at least confused at a higher level! Sagarspezi insist that the 20 Euro unit they sell should work, so do I cross my fingers and buy that, or spend quite a lot more via son-in-law in the USA (he can save me £30 shipping!) to get just the trigger unit?
Or just dive in and try to replace the capacitor in the one I have???
It’s definitely a good place to start not to mention the safety gear .I have the 880, just like that and I wished it had a kickstart instead of a pull start. I have my chain on the right way round though, it cuts better.
your right! Thats not so clever!I have the 880, just like that and I wished it had a kickstart instead of a pull start. I have my chain on the right way round though, it cuts better.
….George Carr in Bristol (Matt)It maybe worth searching for an original working model of your saw for sale on the usual sites , this could be used as a donor for other parts you may need . I personally only use stihl equipment chainsaws blowers and strimmers etc as the back up service from stihl is pretty good . However as a word of warning make sure your supplier registers your product with stihl as they won’t accept it from the buyer and therefore you can lose your warranty . A lot of online suppliers will not tell you this so you won’t find out until you make a claim. Also keep your proof of purchase as this is also a requirement for warranty claims. Radmore and Tucker or Sam turner and sons are both excellent to deal with ( hope I’m not breaking any rules naming these companies)
Thanks, Noel. Yes. I saw that post a bit back, but at the time it was just gobbledegook. Now I've learned a bit more, I think it makes sense. In the meantime, have found a supplier of the trigger module in the USA for about £20, so S-i-L is probably getting a commission. Problem with option 3 is that the module looks like a total pig to open up without damaging the encapsulated electrickery!I’d go for option three at this stage.
I copied this from one the forestry forums a few years ago:
Often the simplest of fixes , took a large sycamore down today and my stihl saw fired up without any effort after several months of not using it , however my old mcculloch refused point blank to even cough, plugWell, here is one VERY red-faced, but slightly happier, bunny. Bought a cheapo spark tester and bingo, there seemed to be a perfect spark. Repeated the test with the actual plug, and it sparked too. Why, I have no idea; definitely didn't work when first tested or several times in between. So today, gave it a fix of easy start, pulled several times and it ran until the easy start in the air cleaner exhausted. A few more tries, without much change, then, presumably, it managed to get enough fuel into the carb and away it roared. I wasn't kitted out to do any cutting for real, so no doubt when I get my PPE on tomorrow it will refuse to play.
But have learned quite a bit about part numbers, solid state ignition etc. as a result of this. And reinforced what has been obvious for years, I just don't understand 2-strokes.
To add to Noel's useful extract about flywheels, the important part number is cleverly concealed on the back of the flywheel, so you need to take it off to check.
It's always had one!Don’t forget a new NGK plug,
I assume you're using a fresh petrol mix with the correct mix proportion for your model. I have a newer Stihl and it plays up something rotten if the mix is old. I use this stuff to keep my petrol fresh. Mountfield MS1220 Universal Fuel Stabiliser 250ml | Oils & Additives | Screwfix.comWell, here is one VERY red-faced, but slightly happier, bunny. Bought a cheapo spark tester and bingo, there seemed to be a perfect spark. Repeated the test with the actual plug, and it sparked too. Why, I have no idea; definitely didn't work when first tested or several times in between. So today, gave it a fix of easy start, pulled several times and it ran until the easy start in the air cleaner exhausted. A few more tries, without much change, then, presumably, it managed to get enough fuel into the carb and away it roared. I wasn't kitted out to do any cutting for real, so no doubt when I get my PPE on tomorrow it will refuse to play.
Have you changed the fuel filter? My sop’s with any temperamental saw. New fuel filter, new plug. If that doesn’t solve the issue move on to other things. One of the first things i was taught when i became an arborist 35 years ago….Well, here is one VERY red-faced, but slightly happier, bunny. Bought a cheapo spark tester and bingo, there seemed to be a perfect spark. Repeated the test with the actual plug, and it sparked too. Why, I have no idea; definitely didn't work when first tested or several times in between. So today, gave it a fix of easy start, pulled several times and it ran until the easy start in the air cleaner exhausted. A few more tries, without much change, then, presumably, it managed to get enough fuel into the carb and away it roared. I wasn't kitted out to do any cutting for real, so no doubt when I get my PPE on tomorrow it will refuse to play.
