Well, it is to me. I first saw this whilst looking for a parcel-increaser to justify the postage costs of buying some flexible measuring scales from that Fine Tools in Chermany. (See photos). A mere 20.5 euros.
I have left hand and right hand skews of 6mm and 12mm blade width but this spear-point item seemed a good idea as it's two (LH & RH) in one. It;'s also cranked - a feature I use a lot these days because of doing smaller work than heretofore.
Two Cherries are a bit suspect i' the chisel as they do that high gloss polishing of the back - which can also badly dub the edge. However, this one isn't too bad - the back had a slight concavity but flattened in 10 minutes back to a high polish via 140 - 2500 grit papers on glass, with only a teeny bit of dubbing to get rid of at the cutting edges. Perhaps all the moans about the dubbing on the interweb, over the years, has improved their polishing process?
I put a teeny micro-bevel of about 30 degrees (ish) on each of the bevel edges by hand - just 3 or 4 rubs each on 9, 3 then 1 micron papers on glass per edge. This was enough to get rid of the grinder marks on the 25 degree bevels.
It cuts the softwood end grain very cleanly and readily. Time will tell if the edge lasts. It'll be used mostly in hand-paring fashion to clean out the bottoms of tails & pins in various hardwoods such as oak, sapele, cherry, maple, ash and teak.
Does anyone else have one of these? I've never seen one in the usual Blighty web emporiums. They seem an obviously good idea compared to having two (LH & RH) skews. But perhaps I will discover a difficulty when using them "in anger". .....
Eshmiel.
Eshmiel.
