motownmartin
Very clever, Looks good too =D>
MooreToolsPlease":rlqau2lr said:Are those fillets glued in? would this be a potential problem with the movement of the parts?
Usual practice is to set the drawer fronts back around 1 or 2mm from the front surface to create a shadow gap, but it all depends on the type of effect that you're after - RobA question about the drawers, I've built this with a mind that the draw fronts will be flush with the face, but I'm mulling over the fact that I could make them a little bigger and have them protruding out the thickness of the front, or I could even leave them the same size as the opening and let them recess say about 1/4" so they look much like the back panels. What does the forum think?
DomValente":1gkdqpzy said:Boy you work fast LN, wanna job![]()
I would leave the drawers flush on this piece, I feel it would work better, but only if you can get them dead flush.
Dom
devonwoody":3pw8bw3n said:Another question what wood for the drawer sides and back?
I usually go to my offcut box. but traditionally dont they use any seasoned timber available for these parts and the least expensive
LN - almost any timber can be used providing it's hard wearing and stable (not prone to movement) Generally quarter sawn oak is used about 8-10mm thick for the sides and a little thinner for the back. A better colour match for the ABW might be some hard maple if you've got any in stock. The drawer front grain should I think be horizontal, this would also give scope to make some half-lapped d/t's for the front joints - RobLord Nibbo":7j0l01pe said:devonwoody":7j0l01pe said:Another question what wood for the drawer sides and back?
First thoughts were tulip/poplar, what is the most common used?
edit....
Just had another thought about the fronts, which way should the grain run? they are nearly square, the rails are obviously running horizontal but the uprights the grain is vertical, everything tells me it should be horizontal but I'm not so sure.... :?
