Amazon Fire stick - Questions from a tech numptie.
Chubber
25 Apr 2024
Lochmaben DG11 1SR
I have a nice 4yr old LG freeview equipped TV I currently use in my dining room for cricket, rugby etc, plugged into an aerial socket on the wall.
I will want to use it in the new house in a room without a socket.
I shall have full fibre Internet 145 mbs.
I believe a F'stick will allow me to continue to do so without a wall socket aerial. Is that right?
Any advice gratefully received, hints tips and so on. If so which model?
(I can usually successfully replace the batteries in my torch at the first attempt, thereafter anything more electronically technical becomes something of a lottery)
As far as I know you won’t need an Ariel as your f stick connects to your tv via the internet / WiFi which you have.
Is that right?!
I didn't know that!
I've had 3 firesticks over the years in order of "power" - up to today's 4K job - and always had them hanging out of the TV set, but with the aerial still fitted.
I must try your idea/revelation!
Thanks, Bingy man!
Is that right?!
I didn't know that!
Thanks, Bingy man!
My x broke the Ariel socket on her tv and the cost to repair was as much as a new tv . As far as I know she went the fire stick route . Like yourself I’m not that good with how this stuff works- fire sticks, streaming etc but I’m thinking the only issue could be watching terrestrial tv channels but again it comes down to which f.stick package you subscribe to ( I think ) I’m sure the tech wizards will put us right ..
I have a tv in my kitchen with no aerial just a fire stick attached. On the rare occasions I watch live TV I do it through the apps like iplayer or itvx, it works fine if you are only watching one channel but you can't channel hop as it means swapping between different apps.
Historically our only choice for tv was to view terrestrial analog broadcasts with an antenna connected directly to the tv or via a coaxial cable.
Then they added vcr’s which used scart cables plugged into the back of the tv but you had to tune into channel 36 to find the vcr’s output.
Next came satellite broadcasting which you received via a dish of some sort that was connected to a receiver (sky box etc) with a fancier type of cable and the signal from your receiver was sent to your tv via another type of cable (scart or maybe hdmi).
Next along was digital broadcast tv , leading to the eventual cease of terrestrial analog broadcasts in some areas and even more as time goes by. These newer digital broadcasts required , in many cases , the replacement of older antennas (the aerial on your roof) with newer digital compatible models or opting to receive the digital signal via another method. The alternative methods to receive that digital signal being over the internet or via a satellite service (either free view or payed subscription) or in some places by a cable subscription service.
below is the blurb from amazon, it very much sounds, as doug71 alludes to above, that it gives you all the streaming apps that you get on a smart tv, but not a replacement for an ariel
  • Stream in Full HD – Enjoy fast, affordable streaming in Full HD, and control it all with the Alexa Voice Remote.
  • Great for newbies – Streaming has never been easier with access to thousands of free films and TV episodes from ad-supported streaming apps like Tubi, Pluto TV, Rad and more.
  • Press and ask Alexa – Use your voice to easily search and launch shows across multiple apps.
  • Endless entertainment – Stream hundreds of thousands of films and TV episodes from Netflix, Prime Video, Disney+, Apple TV+ and more, plus listen to millions of songs. Subscription fees may apply. App buttons may vary.
  • Take it anywhere – Connect to any TV’s HDMI port to access your entertainment apps and enjoy them on the go.
  • Watch live – Get live TV, news and sports with subscriptions to Eurosport, ITVX and more.
  • Play your favourite songs – Listen on Amazon Music, Spotify and others. Subscription fees may apply.
  • Control your compatible smart home – Ask Alexa to check weather, dim the lights, view live camera feeds, stream music and more.
Hhm, very interesting. Not currently too urgent, can watch TV via internet on my tablet but how things all work after a house move has yet to be seen.
Thank you for your inputs.
We use firestick, but plugged into ethernet socket because wifi is too far away. Yes you will be able to watch iplayer, Netflix etc. you will, as far as I know, be able to watch all the regular UK channels through there own individual apps on the firestick. We have diffuculty sometimes but only because we are in Italy and for licensing reasons have to use a VPN which not only slows down the streaming but also can be seen by some of the apps.
Don't forget that if you use internet over mains (google, Powerline Network Adapters). You can buy a set for around £50 (I use TP link) that connects to router plugged into a mains skt near the router (using a patch cable, supplied with the units) and a second unit plugs into a mains socket in another room (you can have multiple units). The connection can then be ethernet cable to the unit or wifi. I have fibre BB and that is how I use ethernet all over this old house. I have used them for years and I find them very reliable. The ones I use have a "pass through socket" such that it doesn't tie up a mains socket.
We haven't used an aerial on our TV for about 6 years, instead relying on an Amazon firestick. In fact we have two TVs in this state. There are Apps for BBC (iPlayer) C4, ITV and I assume they will work without a Prime subscription. I am also guessing there are apps for the other channels, although some might be aggregated. e.g. just checked and the U app provides Dave and Yesterday. Essentially the dongle provides the same experience as watching TV on a tablet.
The dongle plugs into an HDMI port and is powered from a USB input; a small USB triangular charger and cable is supplied, but you may be able to connect to a USB A on the TV if it has one and outputs power. We connect to the house Wifi, currently Fibre, but previously reasonable ADSL without issues. Most of the apps will downscale the quality if the speed is not great.
One minor possible issue to be aware of is the 7pm-9pm slot when lots of people turn on streaming services. This is when the interweb tubes (technical term :)) start to get congested; not just at the street level but at the provider level as well and they can struggle to provide popular feeds such as Netflix. The big ISPs such as BT and Sky will have caches that store the most popular movies so that they don't have to be streamed from further afield. Smaller ISPs won't have the arrangement with the content providers. Having said that it's only occasionally we get some buffering and not enough to cause complaint. Seems like the various backbones have been upgraded since the covid pandemic when surges in demand maxed out a lot of network capacity.
In reference to XTiffy post the Powerline Adapters are a mixed bag. I've had a couple of different types and none of them work well when crossing between rings via the consumer unit. I've got a couple of Unify Wifi APs and the one connected further away using Powerline Adapters is more hassle than it is worth.
I started with Devolo power line adapters when first they arrived on the market. Have never had any problems with the various generations I've used.
They ain't the cheapest, but fo me they are the best. Unfortunately they aren't available in Canada/USA, nor in S.America.
They were the first company to really market a viable product for general use; though they weren't the first company to promote/market them That company/brand (sadly can't remember the name) is no-longer out there.
All I can say is that I have used the TP link ones for years and have never had a problem. I have also never had a problem with differnt ring circuits.
I have to plug in my firesticks. I have one for an older TV and it's plugged into a powerstrip USB port.
I love the firestick, but word to the wise. Even if you turn off purchases via the fire stick people can still start subscriptions. I found that out the hard way. I guess one of my relatives wanted to watch something and started a free trial which I was unaware of till I got the bill.
