I had thought of having some fingers welded together to make up a long section? I'll ask Axminster if they can supply spare ones, might be less expensive to try to source the Chinese manufacturer on Alibaba.Would also have to factor in cost of welding and cleaning up the weld.ColeyS1":19fz0442 said:I'd say you got a good deal there !!! I'd be tempted to ask Axminster if they'd consider selling perhaps 3 long fingers as an extra. It'd certainly tie the two fences together nicely and also support the workpiece completely right the way through. You may find the fingers are rigid enough that it doesn't cause any issues
For the price I think you've got a cracking piece of kit !
Coley
That's a good shout regarding making hardwood fingers. - no fixing required, just slide a short finger in each end so it can't movecustard":18rtojj2 said:I would't faff around trying to weld aluminium and hope it turned out straight. I'd get the straightest grained, quarter sawn board that I could find of a dense hardwood and make up some accurately profiled, long fingers out of that. You could use some tiny threaded inserts as securing fasteners. This would also have the advantage that you could make one for the bottom channel that had a shaped section in the centre which would mimic one of the big advantages of the Aigner.
" This would also have the advantage that you could make one for the bottom channel that had a shaped section in the centre which would mimic one of the big advantages of the Aigner."custard":kz8o7dqd said:I would't faff around trying to weld aluminium and hope it turned out straight. I'd get the straightest grained, quarter sawn board that I could find of a dense hardwood and make up some accurately profiled, long fingers out of that. You could use some tiny threaded inserts as securing fasteners. This would also have the advantage that you could make one for the bottom channel that had a shaped section in the centre which would mimic one of the big advantages of the Aigner.
RobinBHM":3ixb9orh said:If you use an 18mm false fence it may restrict the depth of cut because the shaft hits the back of the fence before the profile depth is reached. A common prkblem with fielding blocks.
OK.Jacob":2pddnhxq said:Chisel, knife, gouge, anything will do to chip off a bit of wood.
I attach some new photos giving a more detailed view of an actual finger.Looking at them do you still think some hardwood finger could be made up? Adding rest of pictures to new reply, file size limitation.custard":1zber8oe said:I would't faff around trying to weld aluminium and hope it turned out straight. I'd get the straightest grained, quarter sawn board that I could find of a dense hardwood and make up some accurately profiled, long fingers out of that. You could use some tiny threaded inserts as securing fasteners. This would also have the advantage that you could make one for the bottom channel that had a shaped section in the centre which would mimic one of the big advantages of the Aigner.
You don't remove the standard fence you add the false fence to it with a few screws from behind. First time you might need to drill a few holes but not thereafter. Price - zero, it's usually a few bits from the offcuts bin.ColeyS1":qstloljf said:It's a five minute job to make a few fingers Jacob, that would give years of use. It'd take longer than that to cut out a wooden fence, find the screws, remove the standard fence, find a screwdriver, etc etc. Don't you think for the price it's pretty good ?
Coley
