Fantastic starter bandsaw. Well used and looked after. I've used it to make bandsaw boxes, long rip & cross cuts in thick hardwoods (oak beams etc) as well as resawing planks. Available with 10 (used but still usable) Tuffsaws blades (in my opinion the best bandsaw blades in the uk). Original fence, mitre gauge, push stick and instruction booklet. Full description available on the scheppach equivalent.
https://scheppach.uk/scheppach-bandsaw-550w-660m-min-or-960m-min-120-mm-cutting-capaciy-hbs261/
The fence has an oak strip stuck (double sided tape - so can be removed) on it to avoid the locking mechanism interfering with long stock being cut. It is also mounted (with bolts) on MDF - one corner of the base is slightly bent, but a shim holds everything securely in place to minimise vibration.
Collection only from Salisbury or can meet somewhere within a 50 mile radius.
