Tuff saw blade order placed First time I have used this company but have heard nothing but good things beforehand
well we know it is 1790mm and on the manual ( sheppach version ) it is 6mm supplied with 13mm max but I am sure someone with one can soon advise on qualityAnd what blades come with it? I know the quality is likely terrible but depending on size might suffice for the occasional curve
They can take a 1/2"/12.7mm blade but, when I tried one, I found I had to keep fiddling with it to keep it running true.well we know it is 1790mm and on the manual ( sheppach version ) it is 6mm supplied with 13mm max but I am sure someone with one can soon advise on quality
Heck of a choice available to choose from! I got pretty lost I must admit... even with reading the guidance page - informative as it is.
I have bought a selection to try out the company (5) but a good starting point might be 1/4" 6tpi and a 3/8" 3tpi
When I got mine last year, I exchanged emails with Ian at TuffSaws about blade selection and, in one of his replies he saidI am trying M42 also and Sabrecut also as well as 1/2".
For general purpose use (with wood, not metal) I'd suggest going for a SuperTuff Premium Blade, 6tpi, either 6mm or 10mm wide.
Edit: link to 10mm blade:
3/8" - SuperTuff Premium 1778mm - 2050mm (tuffsaws.co.uk)
Link to 6mm blade:
1/4" - SuperTuff Premium 1778mm - 2050mm (tuffsaws.co.uk)
Count yourself lucky I have 9:42pm to 11:42pm ha ha yeah rightGot a delivery slot at 7:07 to 9:07 pm
You may be as lucky as I was and get it delivered two hours earlier than the last time given. Mine was just after 10 but last time slot given was 11:58 I( was just checking and the update showed he had two before me and he turned up at the door.Count yourself lucky I have 9:42pm to 11:42pm ha ha yeah right
I might ask the missus to stay up late so she can answer the door
I mean it’s only fair as it’s her present to me
I think your bandsaw will struggle to fully tension the M42 blade so I would stay away from that one but the Premium ones are ideal and the blade life on them is still really good and will last longer than other Carbon based blades.
Entirely up to you but, given his reply, if you've already ordered you might want to contact Ian about changing the M42 for a different blade
