big soft moose":1ozd8gga said:cornucopia":1ozd8gga said:For saying what a awkward wood it is to turn-and teh problems you've had- i think you've done a great job Miles
yep - i'd second that , by the sound of it you did well to produce any kind of bowl from that blank.
btw on the subject of the ring centre adaptor - i find they go missing all the time - it doesnt take much to make them jump off , so my solution (tho its not my idea originally) is to cut a X in a tenis ball or a squash ball if you need to fit it into a small space, and shove it over the pointy centre.
how are you set for special wood for grandma now ? - I can have a rummage in my pile for character blanks if you want.
What do you mean about the squash ball? Is this a way of forming a sort of spring washer to hold the circular bit in place or a replacement, in which case doesn't the pointy bit just stick out of the X? I suspect I'm being thick!
I will have another look under the bed for a dry blank but will come back on your kind offer if I don't find something (suitable beer tokens will of course change hands )
I was thinking of trying out epoxy filling / dying techniques on this little beauty - filling the worm holes and maybe dying the centre - again with a 1 day deadline to preserve my comfort space for the weekend
This will require that I re-attach a glue chuck to the bottom (which now has a lovely curve on it) so that will be the first challenge. Worth trying though as this bowl is next to useless unless I find a way of dealing with the worm holes.
Miles
