Benchwayze
Hi Folks,
I have to make a fire surround and mantle. Before I do this, I have to tile around the fire itself (A Baxi gas/back boiler fire.)
According to British Gas, I can't surround the fire with a flammable material, such as melamine faced MDF. So I decided on porcelain tiles. I know how to cut tiles, but my problem starts with the relationship between the dimensions of the tiles, and the dimensions of the fire itself.
I am trying to avoid cutting 'filler tiles' at the sides, (or in the centre) and also having to cut a corner out of the tiles situated at the left and right top corners of the fire. (I hope I am explaining this clearly!!)
To get around this, I wondered if I could use a suitable pattern of mosaic tile? These tiles, I believe, are attached to a card or paper backing. This would make them easier to cut neatly, to fit around the fire and would also 'hide' any tiles that I need to cut into a smaller size to fill gaps.
So the upshot is, are these mosaic tiles in fact, on a flexible backing that I can cut with a Stanley knife?
I am sure some of you pro bathroom and kitchen fitters will know this. Of course, any suggestions as to a good make/line/type of tile would be most welcome.
Sorry to be a pest folks, but I would be extremely grateful (No pun intended! ) for any info.
Many thanks in Anticipation.
