hunggaur
hi folks
just purchased a new oak table upon inspection there is a small pimple in the middle of the table top (1 mm high, 3 mm diaminter).
Upon investigation it appears that a fixing screw has been screwed to deep from below and has pushed up the fibers/veneer on the top surface of the table causing the pimple.
i have removed the affending screw but the pimple is still there as it appears to have broken and pushed up the wood/veneer fibers.
can anyone give me some advice as how to best fix this problem. The best i could come with is to center punch the fibers back down and fill/hot wax the dent that would be left.
any advice welcomed.
many many thanks
jon
many many thanks
jon
