Stropping after honing is simply removing rag left by one's finest stone
Fromey":cvcoz8p9 said:I still seriously think it's possible that at the very small scale of the cutting edge and considering how fine a point it is, that there may be sufficient heat generated from the friction of the blade passing along the leather to temporarily melt the wax. Considering how easy it is to melt the stuff and how easy it is to make noticeable heat through friction, I see no reason why you would need thousands of RPM to get this effect.
Lons":2xwg7ati said:Stropping after honing is simply removing rag left by one's finest stone
Yebut....I don't use a strop for that reason. The chisel after fine stone is easily sharp enough for my personal needs. What the strop does for me is 2 things (remember I'm talking carving chisels especially).
1). Stropping polishes the bevel which is important when cutting hardwoods as it "slides" through the timber more easily and leaves a polished surface on the cut.
2). Using it regularly by touching it up whilst working keeps the edge cutting for longer between sharpening.
Works for me, but each to his own and not worth arguing about surely![]()
Bob
Pete Maddex":1bkdhch7 said:Well that's his opinion, its not mine I use Autosol on the smooth side of leather and it gives a better finish (shiner) than 8000 grit and a sharper tool.
The thing is we all do things differently but end up making our tools sharp.
CStanford":24f07pv4 said:Pete Maddex":24f07pv4 said:Well that's his opinion, its not mine I use Autosol on the smooth side of leather and it gives a better finish (shiner) than 8000 grit and a sharper tool.
No arguments from me. At least you realize that you're polishing and not stropping, and using an appropriate compound for doing it by hand, rather than the wax buffing sticks.
You'd get better results on felt or linen but if you like smooth leather then don't change a thing.
The effect from polishing is very fleeting, but you can keep going back for more. Polishing an incompletely finished edge is like wearing cologne after two weeks of not bathing. If you're using an 8,000 grit stone then your edges are 'finished' by any reasonable standard. Polishing up is a bit of icing on the cake.
Lons":3gauhfji said:CStanford":3gauhfji said:Pete Maddex":3gauhfji said:Well that's his opinion, its not mine I use Autosol on the smooth side of leather and it gives a better finish (shiner) than 8000 grit and a sharper tool.
Well I'm exactly the same as Pete and I don't agree with your analogy of wearing cologne which is a ridiculous comparison IMHO, (I said I wasn't going to argue #-o ).
I polish the bevel for the reasons I stated and when the edge loses it's sharpness I soon know when it's time to use the stone. I strop by hand (mostly) because it's quick and convenient, I own a Tormek T7 so have an excellent means of powered leather wheel should I so desire.
As I said - each to his own - we all use the method that we've found works for us and whilst I try to keep an open mind there seems to be a hell of a lot of over complication and bullsh*t flying around sometimes.
Unless you're a sharpening freak or a student doing a thesis on the relationship of a steel edge to abrasive then if the tool cuts the way you want it to, what's the problem?
Bob
CStanford":1gsg415j said:I easily have less than $200 invested in my entire sharpening kit, including decrepit Craftsman 6" grinder. Pretty simple. Pretty minimalist. I probably have the simplest kit for honing of anybody who has posted in this thread.
CStanford":2yyguivh said:Maurice Fraser:
"The purpose of stropping is not to abrade more metal, but rather to continue bending, flexing, fatiguing, and burnishing off the miniscule metal strands still clinging to the edge of the blade after the burr breaks off. If you sharpen with waterstones and use a "gold" 8000 grit stone as a final step, stropping is not necessary." End quote.
mac1012":23bfbaw9 said:hi I have been looking for leather strops to buy I have seen one on the tool post here
http://www.toolpost.co.uk/pages/Grindin ... stems.html
its the one on the board and with handle this design is better for me as I can grip in my dumb head shave horse
I having made and sharpen on the go at craft fairs
I could make my own as I have plenty of nice flat pitch pine knocking around and I am a regular scoll sawer so making the base with handle would be fine I just not sure what leather to use I have seen people say you can use leather of a belt ? so could I go and purchase a cheap wide leather belt and use that ??
and which side is best to use the smooth or rough or both ?
or if any one has any other leather choices that they have used as I would prefer it 3 inch wide like the one on the tool post site
and what would be best way of sticking to the board pva as I want to make sure it is flat and well stuck down or maybe I would be just better buying the one at tool post as its 80mm wide and 15 pound with postage
mark
