It depends on the saw as well. The guides on my ts55 for example are longer than on my titan. A titan that's not wholly on the rail can waver a bit while the festool is a bit more lenient from what I've seen.
Mike, I'm not sure what your issue is about the sheet and the far end dogs? The edge of the sheet should be against 2 dogs while the rail should be against 2 dogs perpendicular to the ones for the sheet. You can of course use the rightmost one for the sheet for the rail as well.
This only works if the 4 mfts you've fitted are perfectly aligned with each other of course.
Another issue you might run into is the motor housing hitting the tall dogs bracing the rail. I tend to use shorter ones to avoid the annoyance.
