denmen
Anyone tell me the best Stanley to get for planing doors/tables etc
ED65":11q9a2yd said:An old one.
Expect to? No, I disagree. Be prepared to do a bit of work yes but expecting to do all that just because the plane is a bit old? Not really. I’d start by knocking off any loose rust and properly sharpening the iron. Set it for a light shaving with the cap iron close and if that works for you stop there; you are done. If you have specific problems then diagnose and remedy those as they come up (most likely the need to fettle the cap iron). It’s definitely not the case that all old Stanleys are lemons that need a project plan doing to them before they can take a shaving. Far from it.thetyreman":311hvfvk said:ED65":311hvfvk said:An old one.
+1 but also expect to do quite a bit of work on it, including flattening the sole, lapping the blade and fine tuning.
memzey":3awnmvfp said:Expect to? No, I disagree. Be prepared to do a bit of work yes but expecting to do all that just because the plane is a bit old? Not really. I’d start by knocking off any loose rust and properly sharpening the iron. Set it for a light shaving with the cap iron close and if that works for you stop there; you are done. If you have specific problems then diagnose and remedy those as they come up (most likely the need to fettle the cap iron). It’s definitely not the case that all old Stanleys are lemons that need a project plan doing to them before they can take a shaving. Far from it.thetyreman":3awnmvfp said:ED65":3awnmvfp said:An old one.
Out of context; how? You stated that the OP should expect to do “quite a bit of work, including flattening the sole, lapping the blade” etc. and I disagreed that’s all. I’m simply pointing out that not all (or even most I’d say) vintage Stanley planes need “quite a bit of work” in order to perform. Some might need a bit, of course and a few might be complete lemons requiring serious attention but most vintage Stanleys are eminently useable with the minimum of work and most of the rest are quite close to that standard with a little bit more attention. Only the real lemons need a complete strip down and rebuild IMO and as decent old planes are still fairly common, the smart thing to do would be not to buy the lemon and pick another plane! Just don’t be put off of decent old planes by horror stories of the necessity to lap and flatten all these surfaces etc before they can be used to trim a door or smooth a surface. That’s not remotely accurate in my experience.thetyreman":2zv1hya6 said:memzey":2zv1hya6 said:Expect to? No, I disagree. Be prepared to do a bit of work yes but expecting to do all that just because the plane is a bit old? Not really. I’d start by knocking off any loose rust and properly sharpening the iron. Set it for a light shaving with the cap iron close and if that works for you stop there; you are done. If you have specific problems then diagnose and remedy those as they come up (most likely the need to fettle the cap iron). It’s definitely not the case that all old Stanleys are lemons that need a project plan doing to them before they can take a shaving. Far from it.thetyreman":2zv1hya6 said:+1 but also expect to do quite a bit of work on it, including flattening the sole, lapping the blade and fine tuning.
you certainly took that out context, obviously measure the plane first, I've yet to find one anywhere near flat, all of my vintage ones needed work before they were how I wanted them to perform.
Have to disagree as well, sorry. Especially about flattening the sole, but that's one of my personal bugbearsthetyreman":1w77oto6 said:ED65":1w77oto6 said:An old one.
ED65":2a18454m said:Have to disagree as well, sorry. Especially about flattening the sole, but that's one of my personal bugbearsthetyreman":2a18454m said:ED65":2a18454m said:An old one.
Putting aide the obvious thing that the original condition of the plane determines how much work is needed overall, I'd say it's true that most planes found in the wild don't need work on the sole. I usually don't even check the sole for flatness, instead I check how the plane works and if it does (which I've found to be the norm, even on smoothers) then I call it good.
I don't lap the flats of chisels or plane irons routinely either. I concentrate effort near the tip – generally the only thing that matters and definitely the only thing that matters on plane irons – and this shortens the time needed by an incredible amount (to judge by how long many say it takes them to prep a vintage iron). I always informally keep track of the time spent in my head but to have actual numbers I have put a stopwatch to this a few times and for irons in okay shape it usually takes about 10 seconds to raise a burr over the majority of the edge; one of the last times I did it it took exactly six strokes, or three seconds.
