devonwoody
My new tspp250 record tablesaw has the extra of a pull through attachment whereby a lever is pulled and the blade travels down the throat and provided the timber is fastened down (using the mitre fence) will make a decent cross cut.
However on releasing the lever the blade returns to a normal tablesaw position. but on my model the blade is not fixed like a normal table saw.
This means that the blade is floating unless I turn a plastic toggle to set the blade in a normal stationery position.
Do other users saws of this model automatically relock themselves or do they also have to operate a plastic toggle to lock up the blade?
Could be dangerous if you forget to turn plastic knob????????
