blackbulldog
Hi,
The missus has tasked me to build a double wardrobe (1100w x 600d x 2150h) and a single wardrobe (500w x 600d x 2150h) approx.
I've built workbenches and cabinets for the garage before but this will be the biggest build so for for me so just wanted to check out some stuff:
Going to use 18mm MRMDF for the project (9mm or 6mm for the backs) and will be building it using biscuits and glue. Is that a reasonable choice of material?
Should the 'top' and 'bottom' fit on top/bottom of the sides or inside the sides?
The double will have a full width shelf at the top and bottom. These shelves will be used to store general 'stuff' so don't really have an idea of the kind of weight they will need to bear but, being realistic, I'm thinking they will have to bear at least 20 or 30kg.
With this in mind, I'm thinking I'll have to reinforce the shelves but not sure of the best way to do it. Maybe use something like 63x38 CLS for the 'rails/stiles' of the shelf and clad that in 6mm mdf? Is there a better way to do it?
Same question for the top of the double ... will that need to be reinforced to not sag under weight too? If so, whats the best way?
The doors will be quite large so I'm wondering how many hinges will be need. Is three on each enough or will I need more?
Also, is there a 'standard' way to measure hinge placement?
Thanks in advance.
P.S. I've got basic tools - tracksaw, mft -type table, drills etc
Thanks in advance.
