Hello,Hello everybody,
Our house was built in 1970s with cavity walls and aluminium door.
We have recently replaced old aluminium door with a PVC one (installation day naturally fell on the coldest day of this year so far).
Part of the reason to replace the door was an assumption that it will improve thermal performance and make our entrance hall warmer.
In actual fact - entrance hall now feels considerably colder, so much so, that I had to hang some heavy curtains trying to keep some warmth inside.
I am a bit puzzled as to where to go from here and looking for advice:
A. Is there something wrong with the new door (I can not see any obvious gaps) i.e. why did it get colder than with the old aluminium door
B. What is the best way to thermally insulate areas 3), 5), 6), 7) leaving some space for finishing wall/floor covering
For context: the original idea was simple - once the new PVC door is installed - to raise areas "3)", "4" and "5)" (see photo) to the level of the main floor with some cement/screed and then lay some floor covering on top.
Space available:
3) is 70mm below main floor level
5) is 30mm below main floor level - it used to be where stairs ended, but last large step had to be reduced in depth due to new door position and hinges on the left
6) and 7) can not add more than 15mm without encroaching too much on the door frame
Areas 8) and 9) always have considerable amount of moisture/condensation in the morning.
Does anyone have any suggestions on how to fix this mess? It sounded so simple in theory...
I did discuss the temperature drop with our door installer - he was unable to suggest anything.
This comes down to doors come in a wide range of quality just like our woodworking machinery, the main difference being they don't come from asia. One way to tell a doors quality is it's stiffness, some you can easily twist and others just sound hollow but the ones I fitted were rockdoors made by GAP Rockdoor | Composite Doors | GAP Ltd .What I do not understand is why the original (theoretically inferior) door was better than a brand new (supposedly "better") PVC door at keeping warm air inside. That's not to say that aluminium door kept a lot of warmth, but certainly did better job than the new one.
Agreed. OP could take a look at superquilt ot similar, fit battens and staple then counter batten then pir insulation. The superquilt will act as an excellent vapour barrier as well as insulation.Hi a damp wall from condensation will alway be cold. You may want to look at using some sort of membrane if you insulate it. These guys are quite good for technical advice
Home • Ecohome Insulation
This sound like an interesting approach. However - given how small my now "ex-rain porch" area - if I cover it with something impermeable, would not this just cause any moisture from the walls and ground to travel a bit further into the house and surface on on the original internal plastered walls as well as floor?Rather than sucking out moisture from the bricks, which is an endless task in the winter, you need to vandex the brick walls and floor areas. ( its a tanking slurry )
Thank you @mikej460. I will keep this in mind.This condensing process reduces the surrounding temperature. So some sort of vent is needed, possibly one with a dehumidifier sensor in it that you normally fit it bathrooms. Or just a manual vent.
Agreed that the letter box is a problem. Problem is - when it comes to selling the house - I am not sure I want to advertise that there is something so wrong with the house that we had to block the letter box.Hello,
The letter box can cause a lot of heat loss. These are and English phenomenon, suggest you block it and put a post box outside, better still a parcel box.
Thank you. Will keep this in mind.There is not much you can do to the brickwork either side, check that the cavity has been cavity filled with insulation material and line with foil backed plasterboard. The floor could be insulated with foil backed material depending on the finished surface.
Based on your and many other comments it looks like the tiles will have to be removed to gains some more depth for insulation.It looks like there are quarry tiles, one could put down a barrier layer even dig up put down some polystyrene and pour concrete over to insulate floor, depends on how much trouble you want to go to.
There is a radiator (about 1 meter from the entrance on the left wall) and it is quite big, but with the current energy prices we can't run it at full power all the time. I understand what you mean though and it looks like its TRV will have to stay fully open for a while, to speedup the drying process.Have you a radiator in the hall, you may need to upgrade the radiator.
Yes. I can't believe how screwed up this turned up. Main reason for installing the new door was to avoid having to pay for the whole porch. Live and learn....Have you got room outside for a porch.
To speed it up I highly recommend a dehumidifier, desiccant if its a cold room, ordinary if its warm.A damp expert (a proper one) once explained to me about how long it can take for walls to dry out and how much water there can be in them.
We were talking very damp old walls so not quite the same but what stuck with me was he said it's similar to leaving a bucket full of water stood in a room and waiting for it to evaporate, which I imagine would take quite a while!
Thank you. Based on what everyone in this thread has said and the bucket example @Doug71 mentioned it looks like a mains powered active dehumidifier is going to be the quickest in this instance. I have not had much success with the passive/chemical ones in the past - they take way too long.To speed it up I highly recommend a dehumidifier, desiccant if its a cold room, ordinary if its warm.
Desiccant (passive) only works well in a cold room or workshop. So you're right to use a mains ordinary one. You can hire them but they do tend to be a but industrial and ott and noisy so best to look online first.Thank you. Based on what everyone in this thread has said and the bucket example @Doug71 mentioned it looks like a mains powered active dehumidifier is going to be the quickest in this instance. I have not had much success with the passive/chemical ones in the past - they take way too long.
This is an interesting contraption. Have not heard of this before. Will keep it in mind. Thank you.How about something like this I have read about them but not used I would use this and super quilt insulation
https://www.vent-axia.com/range/pureair-home
Hello,Agreed that the letter box is a problem. Problem is - when it comes to selling the house - I am not sure I want to advertise that there is something so wrong with the house that we had to block the letter box.
Cavity walls of the house were filled at some point (according to previous owner).
Yes, thank you.Hello,
Because you have incorporated the exterior walls into the the interior of the house on one of the coldest days of the year, it will take some time and heat to dissipate this coldness and warm it up,
The exterior bricks which are now internal will also have moisture content so it could feel damp at the moment. Damp and cold feels a lot worse than dry coldness.
Could you elaborate this part please @Seascaper ?It might be worth recording the temperatures to see how it is all be affected by the external or internal temperatures.
