Hi all,
Need to source some adjustable cabinet legs for levelling some kitchen units I am building, but I need access to them from the inside of the unit at the rear (same as rear legs used on Neptune kitchens if you're familiar with them). Adjustable using an allen key from the inside.
Any sources for these anyone can recommend? I've goggled, and I'm using the wrong terminology clearly as I keep turning up the same old plastic legs with the tear-off plastic plinth connectors used on MFI* kitchens for years.
Cheers.
Cheers.
