DennisCA":1x6ufan9 said:I was hoping to avoid that to make any modification reversible. Could one use loctite or something instead, then it ought to be very firmly there. Perhaps red loctite which would require heating the part to get it off again.
That is also why I was thinking the internal threaded part would only be as long as the threaded part of the arbor, the rest would be smooth. I also don't want to be taking the arbor off the machine, that veers into too much work/effort to be worth it.
seaco":1jyb2bka said:Dennis I must admit you do seem to know exactly what you want already so asking opinions on here does seem a little fruitless. I personally think a physical connection between the two arbors is a must but obviously your entitled to your opinion (sorry but I retract my offer to make it as I don't want your health on my conscience) if you get it made I'm sure members here would like to here the results...
I do use a dado on my Unisaw so an extended arbor doesn't bother me, your safety does... :wink:
Spindle":1yb7brec said:Hi
Whilst I appreciate the concerns for the safety of the OP I have to point out that the torque at the spindle tending to tighten the LH thread during start up will be far greater than the torque tending to loosen experienced during run down on a non braked spindle.
Using a locking feature can actually be detrimental in that it prevents the spindle self tightening under start up.
Hence lathe chucks only needing to be positively locked if the lathe is run in reverse.
Regards Mick
wizard":1ndtadja said:Motor is big enough no problem there, all you need to do now is cut the existing thread to the full extent of the shaft
pcb1962":22vq1qw1 said:wizard":22vq1qw1 said:Motor is big enough no problem there, all you need to do now is cut the existing thread to the full extent of the shaft
You don't want to do that, you need the existing plain section of the arbor to register with the extension to ensure concentricity, a thread cannot play any part in that.
