Hello,
Is Mirka Abranet suitable for sanding between coats of varnish?
And separately, when Bob Flexner and others talk about brushing several coats of shellac and sanding them back instead of filling with pumice, is the sanding dust worked into the pores somehow afterwards with the tampon and more shellac, or is the action of sanding itself pushing abraded shellac into the pores?
Do you sweep the surface before applying the next coat?
In this instance would a regular sandpaper work better, as the Abranet excels at moving the abraded particles away from the surface?
Thanks, Paul
Thanks, Paul
