..not what you think - it may not help much with woodworking. I've not heard of this guy before, but courtesy of youtube recommendations.
This guy runs a small part time business sharpening things and he uses nothing that costs much (the jet sharpeners are probably expensive now, but I've had two tormeks and am glad to see them gone - I do recall that the jets were inexpensive early on).
At any rate, what's impressive to me is that he uses concepts to set up his system and it would work with "gooder" stuff or not.
For example, I have beaten everyone over the head about using buffers. But one of the things you can do if you don't love a buffer is use felt at a lower speed, or use small diameter felt. This guy uses a makeshift drill setup for his regular sharpening gear cheaply doing an end-around over the speed problem for light bevel touch up on knives.
It will take some of you folks a little bit of restraint to not go into the BUT BUT BUT's of some of the things he's doing. This is kind of a lost art on youtube - a truly original video from a guy doing things making a video after he figured those things out, and not making a video with bits and bobs taken from somewhere else and then telling you that you're his friends and here's the links to buy things so he can get revenue.
Certainly not posted as the main point of his video (starting a business), more just a good reminder that you can think your way through whatever you're doing and often come up with a better solution than you could buy.
