Usually I use Black Bison wax in my workshop, but through a bit of a ****-up on the ordering front, found myself out and had to buy Briwax, as that's all I could get at short notice.
Briwax seems to give an easier, harder shine, but the smell is something 'orrible. I definitely need the windows open when using it.
But the real problem only came to light today. I like to prefinish my stuff before assembly, so use masking tape on areas that will be glued later. Having done this and then applied Briwax, when I came to peel off the tape, the tape's glue had been softened through the paper by the Briwax, and I was left with a sticky mess all over my gluing area. :evil:
Luckily Sticky Stuff Remover (does exactly what it says on the can, no workshop should be without some, get it from Lakeland) seems to have removed the gunk, but to be on the safe side I'm going to have to sand :twisted: the stuff back to make sure I can get a decent joint.
Another cautionary tale for us all to bear in mind.
B.T.W. Alf, I notice form your pics that you use blue masking tape, which also seesm the popular stuff in 'Murica. Is it any different from the white stuff (colour aside, natch)? Where do you get it?
