I'm a lurker under the Porch; I have subscribed but haven't yet figured out how to post a message there, which is why I'm posting here
Saw a post there from Bugbear on the dangers of the common method of plane-flattening (glass or other flat plate, wet'n'dry, etc) and realised that there's a body of evidence to support his opposition...
Among the other hobbies/interests I don't have time for, astronomy figures high on the list. From whence comes this bit of esoteric knowledge. If you want to make your own telescope mirror from scratch, you buy two round glass blanks (sort of like turning blanks), scatter appropriate abrasive material between them, and grind away in a circular fashion. After some time and effort you, rather miraculously, end up with one convex and one concave piece of glass (a parabolic, concave mirror being the ultimate aim).
So, as Bugbear argues, grinding your plane on abrasive paper is almost guaranteed to produce a concave (or convex) surface, if you do it enough (I don't have the experience to suggest how long is enough).
As an aside, the traditional final grit in the abrasive process of mirror-grinding is common talcum powder. Which always makes me smile when I read people recommending talc as a way of lubricating the surface of cast-iron tables.
