Cabinet is taking shape and going better. More decisions have 'happened' as I have seen how it is. First there will definitely not be a drawer inside the cabinet as there would not be enough room for all the bottles and glasses (!).
So, that being so I have glued up the cabinet with the back which is a book matched 240mm wide sycamore piece within a frame
Then I made some shelf supports from a scrap piece of aformosia - using an ingenious idea from one of the FWW Krenov articles
Basically you cut a i/2 x 4 x 6 inch piece - then on the router cut a cove on each end and then either side and either end a groove....
Then you cut 10mm wide slivers off this
and then cut each end off and then hand carve the cut-off ends to form a shelf support - worked well and was quite straightforward
The shelf I had shaped roughly then used a neat little Japanese compass plane from Rutlands and the lovely little LN spoke shave to finely shape the curved ends of the shelf - I am not certain yet about the leading edge of the shelf - I think I may add a lip or something to it
So here it is at present with one door stacked inside but the cabinet bit otherwise close to being done
I would still like a drawer - which means either adding another section between cabinet and base with the drawer in - or replacing the front curved edge of the base with a drawer. It is 1350 high overall at the moment and my wife does not want it any higher - so that means a drawer in the base or nothing - I think probably nothing but will get the doors on tomorrow and see how it is
Mark
