Lin
Something a bit different. These two are my most recents cuttings. The inner part is raise approx. 1/4" on each. Hard to tell from the pics but the inner outside cut was cut with the saw table at a 4 degree angle causing the piece to be able to raise up and lock in that way. The eagle was cut from 1/2" redoak with the eagle stained to give contrast to the outside piece and the cougar was cut from 1/2" cherry with the outer part stained to give contrast. In comparision to some of the projects I've cut these two were quickly done...both cut in an afternoon.
Lin
Lin
