nev":3kxi4rrm said:
https://www.google.co.uk/search?q=model+paint+chrome&ie=utf-8&oe=utf-8&gws_rd=cr&ei=IDvKVeeZK8avUYjbl6AD
The majority of 'chrome' model paints are only fit for looking vaguely metallic when painted on absolutely tiny bits of model, to be honest. Paint them on something bigger than 5mm across and they just look like lots of bits of powdered metal floating in grey paint. Because they're generally made by floating lots of bits of powdered metal in grey paint!
Plastikote chrome looks decent enough but it's also horribly fragile, in my experience. Maybe not a concern, if the intarsia in question is going to be left somewhere out of the way. There's at least one of those spray-on chrome paints that literally rubs off on your fingers and leaves a grey powdery mess behind!
I've never used it myself but I've seen some of this stuff applied:
http://modelshop.co.uk/Shop/Finishes/It ... ht/ITM4525
and it looks pretty good. As I understand it you burnish it down, though, so you'd probably want a grain-filling finish on the wood first even for something like beech.
Not acrylic, but Alclad do a lacquer chrome which looks awesome but IIRC may give you cancer if you paint it on without a respirator:
https://www.wonderlandmodels.com/produc ... ne-finish/
but as with most lacquer paints, it's pretty robust once it's on. Cheap gravity-feed airbrush kits are a lot better than you'd expect, these days, it's much cheaper than it used to be to set yourself up to spray small parts.
Again, make sure the surface to be chromed is absolutely smooth beforehand because it will show up a lot of surface blemishes you didn't notice were there. One approach I've used with success on sculpted modelling putty is to sand, then paint with a thick coat of paint (acrylic is fine), then wet sand that. Repeat a couple of times just to be sure. Acrylic paint will flow into all the tiny scratches and pits, but sands away much faster than more or less anything (even wood!) so you'll find it easy with high-grit wet'n'dry to bring it to a super-smooth finish. Most chrome paints go on best over black anyway, so do this step with black acrylic and you're already halfway there. ;-)
(Be aware, however, that some types of paint interact badly with other types of paint - react and produce unwanted blemishes, or re-activate the layer below. If you do undercoat and then chrome paint over the top, it's absolutely critical that you test it on something else first to make sure that the two paints are compatible... and leave it a couple of days after the chrome goes on to be sure.)
