Some bloak
I've pretty much decided which way to go with the insulation order of things on my new workshop build.. I intend to put a heavy duty DPM sheet against the (stone) wall. Then build the 3 x 2 stud wall/battening on top of/ against that, and where any fixings penetrate the DPM I'll make good with some silicone at those points. There would be a small void within the depth of the studding behind the insulation but I can't see that being a problem.
My main question; is there any reason why I can't cover the whole stud frame with the Celotex sheets and foil tape and foam all the joint lines/ any gaps ?. This would save all the laborious cutting and wedging of the insulation between the stud work. Presumably it would also cut out any thermal bridging through the studs than if I was fixing between them. And with everything taped and sealed I don't think I would need any further vapour barrier on top of all this?.
I would then clad the whole lot inside the workshop with 18mm OSB, fixing the OSB boards through the 50mm Celotex in to the stud work behind.
Does anyone envisage any problems in this method?. If the Celotex or rigid insulation is good enough to float floors on
then boards fixed against it should be fine me thinks?. Thanks for all your valuable help and advice out there.
