Nigel Burden
As others have said, £20 isn't a lot to pay, and I would expect to have to fettle it at that price.
If you feel that the description does not reflect the condition that you received the plane in then ask for a full refund, but quite often a seller states that the buyer examine the photos as they form the description.
Personally I would fix it as I couldn't be bothered with the hassle of returning it. As long as there are no pieces missing from the tote it should glue ok, and the angle the blade's ground at isn't a problem unless it's way out, or has no meat left on it. Cracks in the casting are a no-no. Having said that, I have a no4 Stanley that was a £2 car boot buy which revealed cracks on either side of the mouth once cleaned up. It was obviously used as a scrub plane as it had a heavily cambered blade. This plane performs ok as a scrub plane, and the cracks do not mark the wood.
This is a personal thing, and it will depend on whether you feel that you can fix it. Paul Sellars and Mitch Peacock have videos on youtube on restoring a Stanley no4 if you decide to go down that route.
Nigel
Nigel
