4mm plug cutter
PerranOak":3co7q385 said:
I'd like a plug cutter of 4mm in diameter.
Would a cutter for a size 6 screw be about that, do you think?
Cheers.
Nope...you need a plug which is slightly bigger that the dia of the screwhead...I'd go for an 8mm plug cutter, preferably a Veritas one - Rob
Sorry, I didn't explain.
I want 4mm (5mm at a push) plugs as decoration, there'll be no screws it's just that some plug cutter are sized, understandably, by the screw size to which they relate.
If you don't want many, it may be more cost-effective to buy the plugs, as here.
There are other sources as well - others will know better places to purchase.
You could use the smallest size of Miller Dowel which comes with a matched drill bit and in a variety of woods.
I'd also second Robs endorsement of the Veritas cutters.
Ed
Miller Dowel is OK if you don't mind end grain - with shrinkage they are likely to end up proud of the surface . The smallest ready made plug seems to be 6mm. I think you might struggle to find a plug cutter that small - the Veritas ones seem only to go down to 6mm.
Jim
If it's decorative, why not use veneer and a hole punch (as used on leather). They come in smaller sizes than plug cutters as well :)
Boz
Or you could easily make yourself a one-size dowel plate (ie drill a 4mm hole in a bit of scrap steel) and then hammer bits of the right wood through. Provided end grain is ok.
Thanks for the great ideas.
I'd like to use the wood that I'm using ... if you see what I mean, then it will always match.
It is decorative but also adds strength as a little pin so end grain is expected.
I tried drilling through a piece of metal, in which I'd drilled a hole, by putting a piece of wood in a drill and drilling down. Would hammering work better? The drilling made the surface all wonky.
If you are making quite a lot of this stuff, 4mm dowel, remove the blade from a metal pencil sharpener and drill out the end to 4mm. Carefully grind the end of the blade to suit and refit. Away you go.
If you are talking a couple of short, less than 25mm, pieces, then an add hoc lathe might just be good enough.
HTH
xy
Hi,
Try cutting the timber for the dowel to 5mm2 sections and short ish lengths- about 100mm. Put a point on the end with a chisel and then knock it through the hole. It should give you a good enough finish.
You can buy dowel plates- this is mine-
I used it too make 4mm dowels for this-
HTH
