A
Anonymous
Guest
Espedair Street":26x2ydab said:
That is the ECE I mentioned earlier. LV and many others sell them. High quality, low price and fun!
I assume to allow plenty of space for the thick chips which tend to be that shape in cross section (thickest in the middle, curving away towards the edges). Although, if the mouth is big enough, I don't suppose it matters much.Now... Alf, what's the point of rounding the fore lip of the mouth?
Well I can't speak for doing it on a Bailey iron, but what I did on my #40 1/2 was:Second question: how to re-bevel the iron (as in the American -thread) without making a whole mess?
On the whole, I'd think not. You might have to set it back quite a way though, but it'll still give a bit of additional rigidity to the blade I think. Ideally a suitably sized iron from a woodie would be good, 'cos of the additional thickness. I really don't know for sure though, 'cos I've never done it!Tony":3gdxulvy said:Do you remove the chipbreaker when converting as the LN doesn't have one?
Agreed - kind of. But backing off the cap iron well away from the edge would solve any problems.Roger Nixon":yqg7pzb2 said:A chipbreaker really has no place on a scrub plane because the shavings (if you can call them that) aren't fragile enogh for the chipbreaker to have any effect other than clogging.
Is that the camber it came with, Roger? I was just wondering because the Old Tool List Archive was extremely contradictory on this! I ended up going with what L-N put on theirs (they must know something, right? :wink: )Roger Nixon":yqg7pzb2 said:My scrub has a much more agressive camber.
Alf":3oj8a7nt said:And timber being the price it is over here, you don't really want to get too carried away with a scrub anyway. :shock: :lol:
Cheers, Alf
Alf":2q5153zd said:Agreed - kind of. But backing off the cap iron well away from the edge would solve any problems.Roger Nixon":2q5153zd said:A chipbreaker really has no place on a scrub plane because the shavings (if you can call them that) aren't fragile enogh for the chipbreaker to have any effect other than clogging.
Alf":2q5153zd said:Is that the camber it came with, Roger? I was just wondering because the Old Tool List Archive was extremely contradictory on this! I ended up going with what L-N put on theirs (they must know something, right? :wink: )Roger Nixon":2q5153zd said:My scrub has a much more agressive camber.
Alf":2q5153zd said:Really what it boils down to I think, is that a converted jack just isn't the same as a real scrub, but it's better than nothing (or the sofa if LOYL finds out you've ordered an L-N...). And timber being the price it is over here, you don't really want to get too carried away with a scrub anyway. :shock: :lol:
Cheers, Alf
Ah, the murky waters of terminology.Roger Nixon":1zkja39m said:What you call a "converted jack" is what I call a true jack
Probably because I neglected to mention it...Roger Nixon":34t8gxcp said:My apologies, Alf. I missed the part about filing the mouth open which would help alleviate the chipbreaker problems.
Possibly all they're good for. :roll:Roger Nixon":34t8gxcp said:Another candidate would be the lowly modern Stanley SB planes.
D'you know, I've never really studied the issue? Hmm, might have to see fi I can find what Charles Hayward says, if anything. "Planecraft" suggests 1/64" - 1/32" for "coarse or rough work", which seems a bit light. I suppose the influence of machine-prepared timber must effect the suggested camber, so perhaps we need something pre-machinery. :?Roger Nixon":34t8gxcp said:Finding specific information on the amount of camber to be used in plane blades is frustrating.
Right. The campaign starts here.Roger Nixon":34t8gxcp said:Because of this lack of information, I feel many people are missing out on much of the fun of planing. Planes with cambered irons are easy to set and use even for beginners and plane sole flatness isn't much of an issue so old metallic and wooden planes can be used effectively.
<buzz> Objection! Oh deary me, we're going to fall out over uncambered jointer irons... :shock:Roger Nixon":34t8gxcp said:Smoothing planes and jointing planes (jointers, block, rabbet, etc) need to be sharpend straight across but planes used for stock prep should all have some camber.
Ah, I like that one.Roger Nixon":4xncpeci said:I think we're dancing in step to the "terminology tango" :lol:
Hmm, I think maybe we are disagreeing you know. Now this may be hard for some people to believe, but I only have one #7 (yes, it's true :shock: I did have a second once, but I was pursuaded to part with it. A black day indeed). It has a slightly cambered iron, and it gets used for trying, jointing, big a** smoother etc etc. Just the one iron, no swap outs for uncambered alternatives or anything. Now while I'm right on board the idea of needing more tools :wink: , does this ever-so-tiny camber really make any difference to the joining of two boards? Unless, of course, you favour a rubbed joint, in which case perhaps it does? Crumbs, this is hard brainwork for a Sunday afternoon! :shock:Roger Nixon":4xncpeci said:I prefer the terms "fore plane" or "try plane" for those planes over 18" with cambered blades and "jointer" for those planes that actually cut the surfaces to be glued or joined. I keep two #7's handy, one with a cambered iron for "trying" and one with a straight iron for jointing or flattening large surfaces.
Now while I'm right on board the idea of needing more tools , does this ever-so-tiny camber really make any difference to the joining of two boards?
