transatlantic
Boom!
Decided to try and copy the Veritas 4 way speed clamp. I am very happy with the results. All you need is finger strength to tighten the nuts to apply enough pressure to close the joints. I also really like how you can fine tune each corner.
I already have some a ideas for improvements
- Adding a bushing to the hole the rod glides through, so there is no metal on plastic when tightening
- Add some feet to raise them of the work surface a little
The only real niggle is that they don't have the quick release nuts the Veritas ones have.
