Well there you go, I bet you could get them here off the shelf too.
@ bobblezard But they will be easy to carve with a small regular gouge too. I'll post something at the weekend about it.
So I'm starting on the capitals for the frame and I've found a nice bit of spruce in the off cut pile. It's just the right size to carve both of them side by side, which should speed things up a bit.
So I just lay it all out with a cetre line and find the size of gouges I need by drawing the outlines of the elements with them. I try to use the same gouges that I used on the other parts of the frame, as the original carvers would possibly had a more limited selection of tools than I do.
That's my theory anyway and it seems to hold true.
Once I'd carved the post for the central flower on the capital cornice, I used a plant pot with the correct diameter for the segment as a template for both of the capitals.
As I'm carving two together, I can repeat the cuts with the gouge I have in my hand and this speeds things up no end.
I cut the segment with a regular chisel held bevel down to cut and carve the internal radius. Then I removed all the waste, as I had my high points and as everything else is below that, I can chop away quite happily.
I cut the cove and the bottom fillet of the cornice and cut a trench down to the second from lowest level on the carving. The lowest point is in another trench and I'll cut that out last.
I'm getting a nice shiny surface from the gouge and chisels and the cutting was easy despite it being mostly end grain, so I know the edge is good. If I have to push, I know it's time to strop the edge and touch it up.
I've also laid out the volutes and cut the angled faces for them at the same time as the cornice. Hopefully I'll have the face of the capitals done tomorrow and I'll start fitting them to the pilasters.
