150mm ducting
RogerS
20 Feb 2004
In the eternally wet North
Intended to fit the cooker hood yesterday, only to discover that the cheapskates at AEG/Electrolux don't include the tuppence worth of plastic ducting to connect the outlet of the hood with their deflector...despite the damn thing costing nearly £600. That is SO CHEAP of them.:evil: :evil:
So, I'm stuck with trying to locate some plastic pipe (only need about 4 inches :twisted: ) of 150mm diameter. I can find 100mm aplenty but 150mm is proving difficult.
Any suggestions ?
Roger Don't forget that there is a Screwfix outlet in Gloucester if you are desperate and travelling to and fro.
Your local electrical wholesaler can probably oblige... I use TLC (www.tlc-direct.co.uk) - lots of branches in many towns. Their catalog lists 150mm ducting in 300mm plus lengths.
Dee
cambournepete":1aw4bih5 said:
Been looking for just the same stuff for the same reason (although I haven't bought the hood yet).
A quick search on google groups got me here (scroll to near the bottom).
HTH
Pete, how much do you need as I've now got some proper 150mm and likely to have a bit spare?
