Any recommendations guys?
I'm making some shelves to add into an Ikea stolmen setup so need decent edges on both sides as the shelves will be open ended and on show.
I'm borrowing a ryobi 150mm blade, 10mm bore cordless circular saw from a friend and plan on putting an new blade in but I'm struggling to find an obvious blade to buy. I've been doing quite a bit of reading on the subject and it looks like I need to find a negative rake blade with as many high alternative top bevel teeth as possible. Unfortunately they don't appear to exist in the size I need. I did find this one which, to my novice brain, would appear to be a reasonable option.
Trend CraftPro CSB/AP15036TB Aluminium / Plastic and Worktops Saw-blade 150mm x 36 Tooth x 10mm, Front bevel tooth form for a superior quality of cut, Micro-granular Tungsten Carbide Tipped to allow cutting of abrasive materials, Body is hardened and tempered to maintain trueness, Blades have a negative hook angle, Suitable for plastic and alloy, Alternate top bevel tooth form, Fine finish for plastic and aluminium, Anti-kickback with thin kerf for cordless saws.
What do you guys think?
While reading I saw several posts relating to the best way to make the cuts and the general advice seemed to vary between scoring the surface, taping the area before cutting, and sandwiching the MFC between sacrificial board. Everyone agreed that a straight edge would be a wise move to ensure a nice straight cut. I'm thinking my best bet would be to tape the surface and then sandwich it between securely clamped hardboard with a straight edge on top of that. Sound about right? Being a complete novice I'd also love some advice on this too if anyone has any they'd care to share.
thanks everyone!
thanks everyone!
