dannykaye
not sure how I would make a sleeve that was 0.35mm thick and 12mm internal diameter, it needs to be a tube with slots basically. Turning a sleeve of that diameter and thickness would be fun on my poor little lathe.
Hmm get a piece of thicker walled tube (copper? something soft compared to hardened steel anyway) about twice as long as you need, bore out to 12mm, cut slots in one half on the mill, put over a piece of 12mm stock, clamp in 4(?) jaw chuck with half of it sticking out (the half that has no slots) and making sure it is fitting well, turn down to 12.7 od, transfer to mill and cut slots, back to the lathe and part off...
sounds fun and should work
