Alpha-Dave
found this video of a guy demonstrating it.
Isn’t the problem that he’s drilling into the support structure of the vice? Second time around he has removed enough of the jaw to let the drill pass through.
I do wonder if that's the difference? For every hole in steel, I drill 100 in wood. I'm on my second box ofnot read all the replies before but after drilling literally thousands of holes in steel over the years
?cheap? drills (apart from replacing tiny ones I break through my fault) and they work fine.
Were I to drill lots, in steel, I guess I'd invest in better drill bits.
If there is a way to sort the wheat from the chaff, I don't know it.![]()
I' didn't know the dead bit on the point of a drill is called the web.
Does the size of this vary much, so a smaller web allows a bigger step in drill sizes as you go up to the required size?
I agree that you can't beat really good quality ones, especially in very small sizes where cheap ones are often not properly formed, however for day to day use I have been very surprised by the quality of the sets from Aldi, the ones they do in a folding plastic case. Both wood and metal bits have been very good, and seem to be very accurately ground. I have drilled loads of holes with the metal working ones in both steel and aluminium, and haven't had to sharpen one yet.
Never really thought about this issue but it seems to me that this will be determined entirely by the angle and back relief used to grind the tip. The issue I have found with the cheap micro drills you can buy is that if you look at the tip they are often a right mess. If you get a dormer drill in say 0.5mm and look at it under magnification it is as perfectly formed as one say 10mm. I would love to know how they grind ones that small. But you pay for it, the last time I bought some they were about £5 each. I use these small sizes in watchmaking. I also have a set of Mikuni carburettor jet drills, again tiny but perfectly formed, and also an eye watering price when I bought them many years ago. If you buy some really cheap and nasty jobber type bits you can sometimes find that the tips aren't even on centre, which makes them essentially useless. Overall I would say if you buy something like a dormer then you know it's going to be good. If you buy cheap then you take pot luck, some will surprise you and be very good, some will be dreadful. But the difference in price is so great you can certainly see why people are tempted by the cheap ones.I was more wondering if different brands, or drills aimed at different materials, would have bigger or smaller webs? So a posher drill has a smaller web for any given size?
"I want to drill some holes in a bit of metal".
Now we're 3 pages in to a bun fight![]()
You've missed nothing, just seemed that way with the thread going on so long. I must be too used to how long threads goI can't see any sign of a bun fight. What have I missed, please do tell.![]()
If you want to find the quality of drill bits, get a Tormek DBS-22. With poor drill bits they just disappear while grinding, whereas with quality bits you get superb usability in both wood and metal. Also found some 12 to 25 mm Chinese bits with reduced shank which cut very well, also in steel.Never really thought about this issue but it seems to me that this will be determined entirely by the angle and back relief used to grind the tip. The issue I have found with the cheap micro drills you can buy is that if you look at the tip they are often a right mess. If you get a dormer drill in say 0.5mm and look at it under magnification it is as perfectly formed as one say 10mm. I would love to know how they grind ones that small. But you pay for it, the last time I bought some they were about £5 each. I use these small sizes in watchmaking. I also have a set of Mikuni carburettor jet drills, again tiny but perfectly formed, and also an eye watering price when I bought them many years ago. If you buy some really cheap and nasty jobber type bits you can sometimes find that the tips aren't even on centre, which makes them essentially useless. Overall I would say if you buy something like a dormer then you know it's going to be good. If you buy cheap then you take pot luck, some will surprise you and be very good, some will be dreadful. But the difference in price is so great you can certainly see why people are tempted by the cheap ones.
