those of us with less "manly" saws can usually just stand a light next to it on the bench. :) you've cursed yourself to these issues buy having a desire to own a saw with enough room to share the work table with at least 4 other scrollers but being greedy.
I therefore have no sympathy for you and your problems of not being able to swing 20" of wood around on your palatial plinth because of your light being in the way.
:p :p (note 1, said with tongue firmly in cheek and green eyes)
(note 2, cracking solution to the problem, I have similar but it's usb powered and sits on the top arm with a magnet)
Hi Brian nice wee lamp I got one out of Maplin with a magnifier but the magnification is too much so might treat myself to a lamp. Was in Lidl Thursday doing the same as you and now am a happy bunny with the ability to switch my dust extraction on and off remotely I am saving up for the Axminster 2.5" pipe and blastgate system so I can set this up in the shed.
I got the last light that the local Argos had, thanks Brian.
I may PM you soon and find out about the cyclone. We are setting up a 'Men's Shed' in Glenrothes and it could be the sort of piece of equipment that would be handy.
take care
Don W
I thought you'd have put a red light on the port side of the table and a green light on the starboard side? :-D
I use a multi-LED bike lamp powered by a 6v 'wall-wart' and a clamp from one of those 'helping hand thingies' with a magnet glued to the base.
It's a Frankenstein job, but total cost ... £2 for the light.
I have 4 sewing machine lights scattered around on various machines. They run off 240v and have a magnetic base with a switch and can be wired directly into a 13A plug or (as I've done on a couple of machines) added direct to the back of the NVR switch on so it turns off when the machine does.
http://www.ebay.co.uk/itm/322197656994? ... EBIDX%3AIT
Col.
    72 KB
linkshouse":gptq7j76 said:
I like the look of these Colin.
How long is the gooseneck?
Phill
Pah! I've just changed my mind!
"Doesn't post to Scottish Highlands"... So, it's coming all the way from Shenzhen, China but can't quite make it up the hills to the Scottish Highlands (or Islands)!!!
I'm sure I'll find something similar from someone that does deliver to the unchartered areas north of Inverness!
Sorry everyone, rant over :lol: :lol: :lol: :lol:
Regards
Phill
Have ordered for collection from local Argos store will collect this evening and make a bracket for it tomorrow afternoon.
After receiving my mag mount lamps as Colin mentioned they are actually better lights not only priced but they are also brighter so well worth getting
Brian
ps Cheers Colin for the link
You dont have problems with flickering?
A add led halogen 230V lamp, and when ex30 mechanism work I receive stroboscopic effect.
