Hi, I've joined here because I need some advice.
I've had a look at the forum and there seems to be some useful information around so I'm hoping you can help me.
I'm looking to start making 1/12th scale fireplaces and furniture for dolls houses professionally as a change of career. I'm currently a Landscape Architect but I'm not enjoying it and things are a bit unstable anyway with redundancies in the offing.
I have been making some furniture for my own dolls house already using Jelutong which I have bought in the right sizes and then cut to length but this works out very expensive.
You can see what I have been making here:
http://georgiandollshouse.blogspot.com/
I have been looking for Jelutong suppliers and have found one in Manchester but the size of planks are 1" thick minimum and 6" wide by x length.
The standard supply is rough sawn but this would require planing it down myself. I can get it planed but I'm looking at buying such small quantities (1 or 2 planks) that it may not be economical.
I have two options:
1) find a supply of Jelutong or similar in the right thickness and use the Proxxon KS 230 bench table saw that I have to cut the right widths, but this only cuts up to 9mm thick.
It would be cheaper than the current method but how do I get the bigger pieces needed for a fireplace - up to 3/4in thick?
2) Buy the big planks and cut my own wood to thicknesses from 1/16th up to 3/4".
I would then need the tools to do the job or find someone who could do it for me cheaply.
I think I'd be looking at a bandsaw, planer/thicknesser and then my little table saw once it's down to size.
What I don't know if how much wastage there would be. How much bigger do you have to cut your piece for planing down to size?
Any ideas as to what tools might be suitable for this sort of work? At these sizes they would need to be accurate.
I need to spend as little as possible really to get the results I need for the most profit.
Anyone have any experience in this and any ideas as to what I might need, what brand of tools might be best?
Thanks very much,
Jennifer,
I have two options:
Thanks very much,
Jennifer,
