Jack, your view is valid but you do realise we run on 230V here, a 20A circuits is a lot of power!
The way you can think of it is like a kettle, would you wire 20A round your kitchen as that’s on of the highest power devices in most homes (that and the oven which had its own supply). So 20A for power tools and small machines is really unnecessary, some need a higher power supply so you wire in a new supply for that, most of us hobby workers don’t have that. Though that’s what I was planing on doing till I inspected the machine and found it couldn’t take 16A itself.
I’ve had a hot plug pin once and that was due to the contact on the socket being slightly bent and only contacting on a point not a flat
Aidan
Hi Aidan...the answer is 'yes' and probably 2 x 20 A in kitchen plus range etc. You say you have a 13A outlet (never seen one so speculating) and I am well aware of the voltages used in US, UK, Australia, France and elsewhere.
I'm not sure whether there was a significant point there in your correcting my discussion.. Through my reply I acknowledged the nominal UK voltage as 220V ..including in the 746W calculation. You may want to be specific if you think your supply is constantly regulated to 230V which is most unlikely. You now are looking at 3.2 amperes not 3.5 under the free running 1Hp calculation. In fact your voltage will be 'all over the shop' demanding on time of day, whether workdays or weekends, local industrial demands and your own household use. Auto switching is a part of controlling all that...but I'll leave it there...
UK and Europe 'harmonised' at 230v however there was no change to supply which was previously nominally 220V. The 230V is a figure between 216v and 250v approximately ..which are the permissable limits of line voltage. At -6% and +10% of 230V it is quite a range.
20 Amp circuits.
The laid up cable and breaker/fuse rating of 20A enables several GPO's to be connected to a circuit using 10 amp outlets. It also suits a 15Amp outlet or a 20A outlet. You use from it what currents your appliances take, the idea being not to overheat cable. We tend to use V105.
The reason for 2 x20's suggested in your workshop(or any) is that 20 amperes is a useful circuit to 10 ampere GPO's and it is a commonplace submains size certainly here. France has some rather 'odd' conception in supply but UK has advanced.
As indicated you have no idea what current your gear draws. You may want to plug in a heater as well sometime..or an air-conditioner...or a dust extractor. Be Prepared is my good advice.
I missed the point on the hot pin...I think you are talking about poor contact and local heating there.
Everything I have written is correct and sensibly conjectured.It may however help to increase your circumspection of me as ignorant of how it all works that I am an electrical engineer many years in IEEE, electrical contractor for 55 years without a single defect on any job, well over 3000 of those, manager (retired) of major electrical organisation, specialist site supervisor here and overseas, electrician special class, tech trades teacher and with various other trades as well as a Masters in OHSE Management. I have watched and worked with the best there was in cabinetmaking and French polishing and use vintage hand tools and power tools.
I acknowledge that your view of my 'view' is of course worthy of response so I have responded to not leave your comment 'up in the air' where it could do damage to other thinking. Hopefully I have clarified it all now.
Warm Regards
