The_Yellow_Ardvark
The price tag said £0:50p, so I had it away.
Soon had it in bits and into the Citric acid.
A nice finish to the castings.
Rattle can paint.
It is has all but small castings of SIF 1940. WDLooks like a Millers Falls 04 drill, so your choice of color for the gear wheel is more or less correct (may/may not be historically correct, but it's a MF color/colour): https://oldtoolheaven.com/millers-falls/hand_drills/drill1.htm and https://www.georgesbasement.com/mfno135typestudy/Drill606/No4D-606.htm
Itis yes.Is that cast in weight on the gear wheel designed to help balance the weight of the turning handle? If so a nuce bit of thoughtful design, I'm guessing it would give a modicum if flywheel effect?
Great job, there’s something very satisfying about taking rusty cast iron and making it look brand new. Now you’ll be able to keep the workshop going even in a power cut!
