Random Orbital Bob
I took delivery late last week after about a month of fairly intensive research. My particular situation is non professional and was upgrading from the RP BS300 which I had found extremely useful over the past nearly 5 years. However, with the addition of wood turning to my woodworking around 18 months ago and the desire to produce my own timber blanks, the capacities for ripping green logs became a limiting factor with the smaller machine. Can't live without features of this saw were that it had to have 12" under the guides and be robust enough to deal with green wood to near that under guide capacity. I wanted to be able to get at least 10" bowl blanks and that was driving the spec. I also wanted a quality saw that would deliver all of the incredibly useful versatility I've come to expect from this most useful machine in terms of resawing, profiles, tenons, veneers etc.
The scope of my research focused on the mid-range trade/serious hobby machines and took in the Hammer N3800, Axy SBW4300B, Startrite 352E and the Jet JWBS 18Q amongst others but they were the shortlist. A combination of build quality, price, delivery timescale, lengthy warranty, capacities and personal positive experience with other RP kit led to the decision on the BS400.
In my research I only found one other review online which was published several years ago by Alan Holtham so I felt it was high time for a customers view that might help others in the decision quandary about which machine to choose.
I took photos of each stage from delivery to the point of testing in use so a new user can get a feel of what they might expect.
This is what arrived
It was palletised and strapped to the delivery van upright. Tail-lifted and pallet trucked right into my workshop. I had hoped for wooden crating and so looked carefully for damage but it had been packed well. with the packaging off front and back. The parts were well wrapped with the wheel kit in a separate carton and the table secured to the front base of the saw.
Record Power are renowned for the copious use of cast iron in their machine tooling and the bandwheels didn't disappoint. They were substantially heavy duty behemoths, these are a massive plus when powering through thick green stock or resawing wide boards. The tyres are thick and wide with capacity for a 1" blade. This has already been tested with a Tuffsaws 1" 1.3tpi "ripper" blade for which I will publish the results later.
The table trunnion and lower blade guards (and over zealous guarding which I have already removed).
The spindle for the handwheel that operates the toolpost (upper blade guard assembly). This just required the wheel to be allen bolted on.
Lower bandwheel and housing
And full frontal with cabinet doors open.
Apart from the table the only parts I needed to fit are shown here which were a small extraction hose and jubilee clips, 2 handwheels (toolpost and V belt tensioner). The rest of the loose items were a free mitre gauge, obligatory push stick and the manual and warranty card + pdi note. I was impressed with this. The fence assembly was already on the table set in the factory which saved me some time. The assembly took less than two hours and though it was a struggle to man-handle the incredibly heavy cast table on my own, it is do-able if you feel confident enough. On balance, I would recommend you get a helper for this step. The table is mounted on the trunnion with 4 sturdy mounting bolts and spring washers to dampen vibration.
Right. This is a WIP and its way past my bed time so......to be continued.
![RP BS400 Review 1.jpg RP BS400 Review 1.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18249-RP-BS400-Review-1.jpg)
![RP BS400 Review 2.jpg RP BS400 Review 2.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18250-RP-BS400-Review-2.jpg)
![RP BS400 Review 3.jpg RP BS400 Review 3.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18251-RP-BS400-Review-3.jpg)
![RP BS400 Review 4.jpg RP BS400 Review 4.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18252-RP-BS400-Review-4.jpg)
![RP BS400 Review 5.jpg RP BS400 Review 5.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18253-RP-BS400-Review-5.jpg)
![RP BS400 Review 8.jpg RP BS400 Review 8.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18256-RP-BS400-Review-8.jpg)
![RP BS400 Review 6.jpg RP BS400 Review 6.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18254-RP-BS400-Review-6.jpg)
![RP BS400 Review 7.jpg RP BS400 Review 7.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18255-RP-BS400-Review-7.jpg)
![RP BS400 Review 10.jpg RP BS400 Review 10.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18257-RP-BS400-Review-10.jpg)
![RP BS400 Review 11.jpg RP BS400 Review 11.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/18/18258-RP-BS400-Review-11.jpg)
RP BS400 Review 1.jpg93.7 KB
RP BS400 Review 2.jpg137 KB
RP BS400 Review 3.jpg117.2 KB
RP BS400 Review 4.jpg223.2 KB
RP BS400 Review 5.jpg227.9 KB
RP BS400 Review 6.jpg130.5 KB
RP BS400 Review 7.jpg109.6 KB
RP BS400 Review 8.jpg169.9 KB
RP BS400 Review 10.jpg124 KB
RP BS400 Review 11.jpg198.6 KB
