Inspired by the success of building my Thien Separator and Mobile Mitre Saw Unit I decided to build another machine.
I bought these plans, https://woodgears.ca/big_bandsaw/index.html from Matthias Wandell's website for his big 20" bandsaw. I don't normally buy plans, I prefer to work stuff out for myself but not having ever owned a bandsaw before I didn't really want to have to solve that many problems and the build drag on indefinitely.
I'm glad I did buy these though, my first impression of the plan package was that they were fantastic and having used them for a few weeks now, this hasn't changed. The big zip file includes the following;
Printed out the first few pages. Not bad for about £18..
So anyway, on to the build. The first thing I did was raid the workshop and my outside timber store to gather enough softwood for the frame components. There's over 70 pieces to the frame alone so I soon realised I'd need some more, enter the skip diver extraordinaire! Two old drawer boxes and a few lengths of 4x3 later and I had enough to get started.
I used the plans to make a cut list and gave each component a letter so I could identify it later. Some of the pieces are quite wide so I had to edge and glue up narrower boards into bits wide enough.
Once all the parts were rough cut to about 20mm thick and 10mm oversized I could crack on with the thickenssing. The plans call for a finished layer thickness of 18mm but Matthias says you can get away with 17mm comfortably. Mine actually ended up about 16.5mm but I am not concerned as all the timber, despite being softwood is pretty good quality. This is just a few of the bits after thicknessing and being cut to finished size.
Next it was on to assembly of the frame. This is done in stages, I started at the centre layer and worked my way outwards, this allows the glue to cure fully on each face whilst I flushed up the joints with the No4. I gave my new Hitachi 16g nailer a bit of a work out nailing the parts together until I could get clamps on any bits that were being a bit awkward.
Finish frame, front, back and some gratuitous supersized finger joints!
Next post, starting on the wheels and upper wheel carriage..
- a sketch up model
drawings of individual components and assemblies
instructions for each section of the build
links to the YouTube build videos
365 photographs
cut lists
hardware list
templates
printing instructions
probably some other stuff I've forgotten!
