We then spent a while moving stuff about and clearing up, we needed to clear half the floor in one go.
We have some heavy-duty polythene for a DPC.
We plan to stagger the joints on the layers of the floor components as well as we can, so we started with a piece of Jablite and then continued with half-width sheets all along the back wall
Then we started with a full sheet of OSB. This is supposed to be 18mm, but at least one sheet is 22mm at one end It certainly is not very consistent. We kept an expansion gap all round the edge
So we have laid about 50% of the DPC, 40% of the insulation and about 30% of the base layer OSB.
We've also had a bit of good luck today. The delivery man had a couple of boards on his waggon. It looked very good. "What's this?", I asked. "
CaberShield", says he, "It's very good stuff".
So I rang up about it. It is a bit more expensive than the ordinary stuff, but it has a bonded polyurethane, non-slip, pre-finished surface. Given that painting the floor would probably cost a hundred or so, the price difference is not so great. So my plan is to use it. At 22mm, it means that I shall have a high-quality 40mm floor on top of the polystyrene, which won't need maintenance. I hope.
