DBT85
Well apart from the Drama of the Missing Poker today was another good day. Father in Law Mike arrived at 10 to help get the mesh down and in little time we got the first layer down and tied together, then then circular spacers wired in and then the top layer tied in too. Apart from that all that was left for the site was to clear up to give us space to work tomorrow.
My 7.2m 75x225 also arrived from Davies timber, a solid lump and nicely straight.
The local hire company (whom we know well enough that I can just walk in and take things off the shelf) delivered a lifting rotating tipping 2 ton dumper and the easy float, but not the fearsome poker. More than a little annoyed at not being told until 16:45 when they knew I needed it for the last 5 days and I even checked on Monday to be sure they had it.
Anyway, off to screwfix to collect the 5x8m tarp and M16 rod. The former to cover the slab and the latter for the rafter/tie joint.
Tomorrow morning the concrete is due at 8:00 from Accumix Concrete (mix on site), Mike will deal with the dumper while Jim and I rake, poke, and tamp the slab. The dumper is a little snug on the access path and will likely only be able to dump from 75% of one long side and half of one short side, so I'm going to be raking a fair bit. Fortunately we're going to have the time it takes him to make his round trip back to the mixer.
In the morning I'm going to try the local hire firms and even places like Travis to see if I can get a poker a little closer to home as Solihul (the nearest HSS to collect from) is far enough away to be a pain in the backside.
Anyway, pictures. I have been doing the time lapse stuff, but will just put one video together for all of the hole being filled. Some has been missed because I thought it was on when it wasn't, but most is there.
A snug fit
All set for the morning
Yesterdays crappy sunset
A snug fit
