Bodgers
This TS200 replacement (kind of) is now available to order, so I thought I'd start a thread for new user's impressions etc.
Just looking at the manual (which is now on the site) a few things stand out...
[The mitre fence slot thingy is now optional and you don't get one at all - the first saw I think to do that. The throw-in ones are always bad, but the optional one doesn't look that great either.
The motor/blade assembly and the way it attaches to the table looks a big step up from the TS200/250.
Blade changes look easier with a locking bar provided that stabilises the arbour whilst tightening/loosening bolt.
Depth of cut goes from 55mm (TS200) to 65mm.
There aren't any bolts on the table top anymore, which is good, but it is unclear how the blade/motor unit can be aligned to the mitre slots...
I like the out-feed and right side extension table idea, but unfortunately they use the same pressed steel style extensions as the TS200 - and they are horrible, so no doubt owners will be replacing them and keeping the fixings...
I think I will order mine within the next few weeks.
